solenoid
120,000 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
BARBARA1963
  • 99 POSTS
I put the scanner on this vehicle and it said pressure control solenoid malfunction. could you tell me what that means and the location of this solenoid.
Aug 14, 2016 at 1:27 AM
BARBARA1963
  • 99 POSTS
This is a four cylinder, not six.
Aug 14, 2016 at 2:38 AM
BARBARA1963
  • 99 POSTS
code is po745.
Aug 14, 2016 at 4:30 AM
HMAC300
  • 48,601 POSTS
see picture for possible causes which can be a TCM or wiring issue we have no pictures of that solenoid as it is inside the transmission which a transmission guy should really look at this. there are two different transmissions for this which one is a CVT transmission and has not been out, but only a few years so a lot of transmission guys are not to familiar with it. it may be a harness /connection problem as well especially as other transmission is doing the same thing as first one did.
Aug 14, 2016 at 6:15 AM
