door control receiver location
150,000 MILES • 3.6L • V6 • FWD • AUTOMATIC
MICHAEL LONG
Where is the door control receiver located on the car listed above it is a convertible?
Mine stopped working and the forums say it is in the roof pillar but convertibles do not have roof pillars so they must have put it somewhere else.
May 4, 2017 at 12:33 PM
STEVE W.
  • 15,410 POSTS
It is in the same place on all of them. Above and to the left of the glove box area on the passenger side. You may want to verify that your key fobs are programmed correctly as the receivers very seldom fail.
May 4, 2017 at 3:26 PM
MICHAEL LONG
I've attempted to reprogram the remotes. After getting the car in reprogramming mode, the door locks cycled twice, I depressed the lock and unlock buttons on the remote simultaneously and the pressed the lock button and nothing happened.
I then went forward and replaced the dcr and went through the reprogramming sequence again and still nothing. Any ideas?
May 5, 2017 at 12:30 PM
STEVE W.
  • 15,410 POSTS
Probably will need to put a scan tool on the car and see what the BCM is doing as it's in program mode. It controls all of those functions. Plus you can program the remote system from the tool.
May 6, 2017 at 6:28 AM
MICHAEL LONG
Thanks
May 6, 2017 at 6:52 AM
  • 55,711 POSTS
Please let us know what you find ;)
Cheers, Ken
May 8, 2017 at 10:43 AM
