Soft top not secure yellow warning light
100,000 MILES • AUTOMATIC
TRACY TURNER JONES
Recently my Audi A4 convertible has started to flash a yellow warning light and says soft top not secure it also beeps constantly.
Jun 23, 2021 at 4:06 AM
BORIS K
  • 836 POSTS
A good starting point would be to get the fault codes read with a suitable code reader.
There are several micro switches which could become faulty and cause this message to show up.
Once the fault codes have been read please update us with those codes relevant to the convertible top function so that we can assist you further
Cheers, Boris
Jun 24, 2021 at 2:19 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
As my colleague mentioned the best thing to do is perform a CAN scan- Controller Area Network on your vehicle to retrieve all vehicle fault codes. A CAN scan will test all the systems on your vehicle including the warning systems you have mentioned for your convertible top. Here is a tutorial showing how to perform a CAN scan:
Once you perform this get back to us with any fault codes and fault code numbers and that will help us diagnose the convertible top issue you are having. Hope this helps and thanks for using 2CarPros.
Jun 24, 2021 at 2:11 PM
TRACY TURNER JONES
Hi, I had the local garage look and they came up with these fault codes:
02000 switch position
01993 motor
0003 ..control unit faulty
As I said I'm not bothered about the roof opening and closing automatically; we can do that manually. just need the roof warning light to stop beeping constantly.
Thanks for you help.
Tracy
Jun 24, 2021 at 8:27 PM
  • 55,688 POSTS
It looks like the switch position is causing the beeping does it look like the top is secured? Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Jun 28, 2021 at 1:39 AM
TRACY TURNER JONES
Yes it does look like it. as I said we can only do it manually ,and we did struggle to get the lock at the back sorted ..but it all seems secure ! I thought I'd fixed it after reading someone else's post by slamming the boot and locking with the key and for 2 days no beeping but unfortunately it started again. what would you like to see on the video? When you say the switch do you mean the switch that would control the roof automatically? Thanks for the help everyone.
Tracy
Jun 28, 2021 at 6:17 PM
BORIS K
  • 836 POSTS
Below is the official guide how to fix the problem. It is a very common issue with this model.
Most likely culprit could be Convertible Top Frame Position Sensor G356 (8H0 959 613)
https://youtu.be/KRtmhgakyuo
Not the best You-Tube but gives the position.
Also see pictures attached below.
A great guide to switch positions can be found here, a suitable diagnostic tool like VCDS should be used .
http://wiki.ross-tech.com/wiki/index.php/Audi_A4_(8E)_Automatic_Roof
Official guide:
During opening sequence, tension bow has fallen out of range and top operation ceases. DTC 2000 (Switch position incorrect signal) will be stored in the Convertible Top Control Unit. This condition is more common when the vehicle is on an incline with the front of the vehicle elevated, such as when parked in a sloped driveway.
DTC 2000 will be the only fault present for this bulletin to apply. If there are any other faults in the convertible top control unit, these malfunctions must be corrected first. Only after these are corrected and the above condition is still present, accompanied by DTC 2000, should you continue.
Only technicians who have successfully completed Self Study Program 991203 - The Audi A4 Cabriolet and course number 991202 - Audi A4 Cabriolet Introduction are permitted to service the A4 Cabriolet. If you have not completed these prerequisites, do not continue with this bulletin. Have the case dispatched to a qualified A4 Cabriolet technician.
Technical Background
During the opening phase of the convertible top run, the front lock lifts from the windshield and the tension bow lifts to a vertical position to allow clearance for the convertible top box lid to open. The lid is then unlatched. During the unlatching of the top box lid and at the point when the tension bow is vertical, the opening strategy calls for the hydraulic pump to shut off momentarily. During this "off period" the tension bow is not under pressure and can slowly drift backwards before the top box lid can unlatch completely. Within this time period, the tension bow may have exceeded its plausible operating range. This will cause the top operation to cease. DTC 2000 (Switch position incorrect signal) is stored.
Production Solution
Optimized Convertible Top Operation Control Module beginning with software 9.0, part number 8H0 959 255B.
Service
1. Address the Convertible Top Operation Control Module and check the control module part number. If the vehicle is already equipped with Convertible Top Operation Control Module 8H0 959 255B, this Technical Service Bulletin does not apply. Any malfunction in the convertible top system with this part number module installed will likely not be related to the subject matter contained in this Technical Service Bulletin. Carry out the appropriate diagnosis and repair relevant to the failure according to the information in ElsaWeb.
2. Should the top operation fail under the conditions outlined in the Condition, do not clear fault memory. Diagnose as follows:
a. Check battery and charging system condition by performing a test with the Midtronics tester. Print results.
b. Check and adjust, if necessary, the convertible top box lid and puller tabs according to the specifications in ElsaWeb.
c. If the top is currently not operating, fully open and fully close the top manually. Power operation should resume.
d. Perform the Guided Fault Finding test plan completely for DTC 2000, checking all five top positions (test of import conv. top positions w. spec. values). Save and print this diagnosis log.
e. If the VIN of the subject vehicle is after VIN 8H_5K009649 for A4 Cabriolet and after VIN 8H_5K901294 for S4 Cabriolet, please also save and print measuring value blocks 6 and 7 to the test plan protocol.
3. If all four of these conditions are met:
- Battery tests good.
- All other top components are without malfunction.
- Convertible top box lid and puller tabs are correctly adjusted.
- All five top positions tested reveal that all switch positions in measuring value block 1 are as specified (no switch implausibility found).
Continue with diagnosis as follows:
a. Connect the diagnostic tester and address 26-Convertible Top Operation Control Module. View MVB 1, field 4. This is the value for Convertible Top Frame Position Sensor G356.
b. Move the top into position 4 from test of import conv. top positions w. spec. values. This position has the tensioning bow up and the cover closed.
c. Turn the key off. MVB 1 will stay live. The tensioning bow can now be moved freely.
d. With the tensioning bow held to its uppermost position note the value for G356 in field 4. Write this value down.
e. At this time note the switch positions in field 2, specifically position 6 (3rd from left). This character will read 1 with the tensioning bow in its uppermost position. Slowly move the tensioning bow down while observing position 6. When this character changes to 0 note the G356 value in field 4 and write this value down.
f. Subtract these two values. If the difference is less than 22, replace Convertible Top Frame Position Sensor G356 (8H0 959 613) with the improved version, which is identified with a yellow dot.
g. After installation, perform J256-adaptation-Convertible top frame position sensor in Guided Fault Finding.
Cheers, Boris
Jun 29, 2021 at 1:52 AM
