Sockets
80,000 MILES
MARKCOLLETTE
I can understand why you would not want to use a regular socket with an impact wrench, is there any reason not to use an impact socket with a regular wrench?
Apr 20, 2018 at 1:11 AM
Good morning.
If you are using a 1/2 impact, you need the impact socket due to its ability to have the heavy torque. the chrome sockets are weak sockets and fracture easily under torque.
If you have a 3/8 impact, that can handle chrome sockets for up to about 40 lbs.
Apr 20, 2018 at 1:34 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I recommend a 6 point impact socket, too but why have you not mentioned what you are trying to use this socket on?
Apr 20, 2018 at 1:46 AM
MARKCOLLETTE
Did you even read my question? Is there any reason not to use impact sockets with a regular ratchet?
Apr 20, 2018 at 10:12 AM
  • 55,560 POSTS
You can use impact sockets and extension on a regulator ratchet.
Cheers, Ken
Apr 20, 2018 at 10:13 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
You said wrench, usually that refers to a normal wrench, ratchet wrench or in some cases an impact wrench. But yes, you could use an impact socket with a ratchet wrench. I would even suggest an impact wrench if using a very long breaker bar wrench. The impact sockets are thicker metal but sometimes can be hard to fit it close spaces.
Apr 20, 2018 at 10:26 AM
