The engine starts, but my dash does not turn on and my transmission will not move?
114,603 MILES • 4WD • AUTOMATIC
STEPHEN SAUDACHE
I can start my engine it is an electrical problem. Engine will start but Dashboard won't light up and I can't shift gears.
Feb 21, 2023 at 5:43 AM
  • 110,248 POSTS
Just for curiosity, do the brake lights work? The shift interlock circuit is powered via the brake lamp switch. That's why I ask.
Now, the cluster issue is different. I need you to start by checking fuses M13 and M20 in the under-hood fuse box/totally integrated power module (TIPM).
In addition to checking the fuses, confirm there is power to and from them. They both should have power at all times.
I attached the wiring schematic for the instrument cluster below so that you have a reference. Also, pics 3 and 4 indicate fuse locations.
Let me know what you find or if you have questions.
joe
Feb 21, 2023 at 1:30 PM
