SMS light staying on and HVAC blower not working
190,000 MILES • 3.9L • 6 CYL • 2WD • AUTOMATIC
CHARLES REBHORN
Had to replace the shifter indicator. Pulled all the shrouds off removed the instrument cluster put in the hew indicator. Plugged the two plugs on the back of the cluster. Put everything back together. Now I have no blower and the airbag light stays on. Any thoughts?
Thanks,
Chuck
Dec 31, 2018 at 2:58 AM
Good evening,
The first thing I would do is to go over all the connectors involved in your repair. it sounds like either a bad connection or maybe a ground wire not connected.
start there. let me know what you find.
Dec 31, 2018 at 9:36 AM
CHARLES REBHORN
Thanks for the reply. I will do that today!
Dec 31, 2018 at 5:02 PM
Sounds like a plan. I will be on and off all day to continue to help if needed.
Dec 31, 2018 at 8:43 PM
