Smoking from back of engine
230,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
TTERRELL03
Car does not overheat or give check engine light but a very faint smoke can be seen when hood is raised. Sometimes it’s bad enough to be seen without the hood being up.
Oct 7, 2019 at 5:46 AM
Good afternoon,
You have something leaking and hitting the hot exhaust.
You need to have someone check it to find out what fluid is leaking and the location of the leak.
https://www.2carpros.com/articles/engine-is-leaking-oil
https://www.2carpros.com/articles/coolant-leak-symptoms
Oct 7, 2019 at 7:27 AM
TTERRELL03
I got one diagnosis of a oil pan gasket leak, but again it doesn’t run hot. show a check engine light, low oil, or smoke from the exhaust. Not sure if I need a second opinion.
Oct 9, 2019 at 1:59 AM
I would get this repaired. The oil most likely is hitting the hot exhaust. You do not want to have a fire from this leak.
No, there will be no codes or running hot.
Oct 9, 2019 at 2:20 AM
