White smoke coming from the coolant tank?
78,000 MILES • 4WD • AUTOMATIC
JOECAF66
I noticed white smoke coming from the coolant tank. The oil level is fine, but I have to keep adding water to the tank before I drive. At present, I am only driving short distances and put water in the tank and carry extra water with me. I have been to two different mechanics, the first one didn't find anything, the second one replaced the expansion tank cap, but it is still smoking. When I told the second mechanic that, he said he would have to order another part, but I haven't heard back from him yet. At this point, should I go see a 3rd mechanic?
May 23, 2025 at 6:49 AM
  • 55,721 POSTS
Yes, I would find someone else, did either of them do a head gasket test?
This is what needs to be done:
and please go over this guide as well:
https://www.2carpros.com/articles/recognizing-the-symptoms-understanding-a-blown-head-gasket-in-your-vehicle
Please go over these guides and get back to us.
May 23, 2025 at 9:52 AM
JOECAF66
I have no idea if any of this was done. I will have to ask the next one. Ballpark figure, do you have an estimate of what this might cost? Thanks
May 23, 2025 at 11:33 AM
  • 55,721 POSTS
It should cost about $2,000 with machine work of the cylinder head. If the system tests positive for gases and they can't find the gasket failure I would have the cylinder head pressure checked for cracks.
May 25, 2025 at 3:56 AM
