smokes
170,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
WASHER
I have let the vehicle set for approx. 5 months without cranking. When I cranked it up it drove ok for approx. 10 miles , then started smoking and a little miss. I was told by friend to put lucas in with oil change and maybe it will solve problem, that it probably was a stuck valve. The truck ran good before setting
Jan 15, 2016 at 5:42 AM
PACO8224
  • 117 POSTS
How much old gas in it. It would be good to put fresh gas. How many miles on it
Jan 15, 2016 at 5:52 AM
WASHER
has new gas 17000 miles
Jan 15, 2016 at 6:00 AM
PACO8224
  • 117 POSTS
Have you checked for engine codes even pending codes
WASHER
no
Jan 15, 2016 at 6:01 AM
WASHER
I do not know why I did not think of that I will do that thanks
Jan 15, 2016 at 6:03 AM
PACO8224
  • 117 POSTS
Ok no problem let us know if you have any more concerns
Jan 15, 2016 at 6:06 AM
