Smoke test
2002 TOYOTA TACOMA
180,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
TINO12345
Have evap issues, so replaced the gas cap, and filler neck tube going to the gas tank. performed second smoke test and still get smoke coming out of the gas cap area. is smoke coming out a normal condition?
Jan 21, 2017 at 6:35 AM
WRENCHTECH
  • 20,761 POSTS
This is a seemed system where ever the smoke is coming out is the leak, you might need to get under the car to see it.
Jan 21, 2017 at 8:17 AM
TINO12345
How can I close vent valve without a scanner?? Would I be able to smoke the filler neck if I remove from tank to isolate the problem?? Like plug all the lines but one and smoke it to see if it leaks thru the same area... Thanks
Jan 24, 2017 at 11:31 AM
WRENCHTECH
  • 20,761 POSTS
There would be no point. You need to know that the vent valve is capable of sealing as it may be your problem.
Jan 24, 2017 at 12:54 PM
TINO12345
Will a scanner from Autozone suffice for the purpose of my test?? Closing the vent valve ?
Jan 26, 2017 at 2:07 AM
WRENCHTECH
  • 20,761 POSTS
No, those aren't real scan tools. They are generic code readers. Real, bidirectional scan tools cost $4000 and up.
Jan 26, 2017 at 2:11 AM
