Used smoke machine and smoke coming out below filler cap
135,000 MILES • V6 • 2WD • AUTOMATIC
JIMHERRMANN
  • 16 POSTS
Get an engine code of a small Evap leak. Used smoke machine and smoke coming out below filler cap. Leak not coming from cap.
Apr 16, 2022 at 3:26 AM
  • 110,246 POSTS
When you say filler cap, are you referring to the fuel tank filler tube? If so, inspect for small rust holes or any evidence of corrosion that could have eaten through the steel.
Also, there will be a rubber hose between the filler tube and tank, check that for leaks as well.
Keep in mind, there are several Evap components around the fuel tank. If possible, check from the underside of the vehicle to tell approximately where it is coming from.
I attached a pic below showing the leak detection pump toward the front of the tank and many hoses related. Any of these can be leaking.
See pics below Pic 2 shows what the filler tube looks like, so check anywhere it could rust and everything from the tank to the filler opening.
Apr 16, 2022 at 1:30 PM
JIMHERRMANN
  • 16 POSTS
Smoke coming out by the filler cap in the fender well. I think there is a purge valve there, not sure if that is what it's called. I think that is where the smoke comes out. I also have smoke coming out of the throttle body.
Apr 17, 2022 at 12:02 AM
  • 110,246 POSTS
I know there is a vent there that is filtered. By chance, do you see the component in the pics I attached above?
Let me know, and I hope you had a nice Easter.
Apr 17, 2022 at 12:14 PM
JIMHERRMANN
  • 16 POSTS
It is the picture with the cap and hose to rank. It is attached just below the cap.
Apr 17, 2022 at 1:03 PM
JIMHERRMANN
  • 16 POSTS
It is the picture of the filler neck with cap. Black object attached to the hose/pipe that allows you to put gas in the tank.
Apr 17, 2022 at 1:27 PM
  • 110,246 POSTS
Okay, that is steel. It may have rusted and developed a few pinholes. Are you able to remove it and inspect for damage?
Apr 17, 2022 at 1:59 PM
JIMHERRMANN
  • 16 POSTS
No rust or holes. Smoke coming from somewhere in fender well. What is the black canister looking thing that is about two inches in diameter? I think the smoke is coming from it.
Apr 17, 2022 at 2:10 PM
  • 110,246 POSTS
Does this appear to be the part you are referring to? If so, that is the vent filter. The OEM part number is listed in the pic.
See pic below.
Apr 17, 2022 at 3:55 PM
JIMHERRMANN
  • 16 POSTS
To order it, it shows the complete fuel filler neck with this part as part of the assembly.
Apr 17, 2022 at 11:10 PM
JIMHERRMANN
  • 16 POSTS
Do you think smoke should be coming out of it?
Apr 17, 2022 at 11:17 PM
  • 110,246 POSTS
I did notice that as well. No, there shouldn't be smoke coming from it. It's a bit frustrating that you need to replace other things that are good, but I tried as well to find just the needed part, and it doesn't seem available by itself.
Let me know if it takes care of the issue.
Apr 18, 2022 at 7:05 AM
JIMHERRMANN
  • 16 POSTS
Thanks Joe. Will try the parts. Will let you know.
Apr 18, 2022 at 7:45 AM
  • 110,246 POSTS
You are very welcome. I hope this takes care of the issue for you. It should. Let me know because I'm interested in knowing.
Apr 18, 2022 at 1:47 PM
JIMHERRMANN
  • 16 POSTS
Will do. I did find the part separately. Have to order.
Apr 18, 2022 at 1:49 PM
  • 110,246 POSTS
Excellent. I'm glad to hear that. Also, it will likely help others to know that information in the future.
I will watch for your reply.
Take good care of yourself.
Apr 18, 2022 at 1:52 PM
JIMHERRMANN
  • 16 POSTS
You too and it might be a couple weeks before I get the part and install it. I was going to tell you I built my own smoke machine for under $20.00.
Apr 18, 2022 at 2:02 PM
  • 110,246 POSTS
You need to send me the directions for the smoke machine. LOL
Let me know what you find.
Apr 19, 2022 at 9:22 AM
JIMHERRMANN
  • 16 POSTS
Another question on a 2014 dodge grand caravan using a doorman dipstick what should the fluid readings be? I know the procedure. My reading is 40 mm.
Jul 22, 2022 at 7:06 AM
  • 55,579 POSTS
Please post your new question here, you must be logged in.
Cheers, Ken
Oct 20, 2022 at 4:46 AM
