Why is there smoke coming from transmission dipstick tube?
247,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
HUNTER ATHERTON
I recently installed a new transmission and haven’t added anymore fluid than what I have already due to even running the truck a minute or two I take out the dipstick and it lets out some pressure and smoke comes out.
Jul 24, 2022 at 12:35 PM
  • 55,649 POSTS
As long as you don't drive the truck you are okay, it sounds like it is low on fluid and what you are seeing is fluid vapor, start the tuck on level ground and add fluid until full. The problem should go away. Here is a guide to help:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
Jul 25, 2022 at 4:11 AM
HUNTER ATHERTON
Edit: Sorry I didn’t thoroughly read your reply.
Jul 25, 2022 at 7:44 AM
  • 55,649 POSTS
No problem. Please let us know what happens. I was thinking there are electronics inside the transmission but they should blow a fuse before smoke can occur.
Jul 26, 2022 at 6:14 AM
HUNTER ATHERTON
I let it run to the operating temperature and filled it to the safe line and she shifted like a dream. Thank you
Jul 26, 2022 at 11:50 AM
  • 55,649 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Jul 27, 2022 at 5:46 AM
