Smoke from tailpipe
220,000 MILES • 4 CYL • AUTOMATIC
HELENG
I have white thick smoke coming from the tailpipe it fills the air with smoke. Would this be a easy fix and cheap to fix? The car has been sitting now for about five months because of the problem. I am a woman so clearly i do not know what it could be .it has a lot of miles but the car was amazing until this issue. Please help i feel i would get scammed into paying more than i need to because i am a woman and do not know anything about cars.
Dec 13, 2017 at 3:34 AM
CARADIODOC
  • 34,414 POSTS
Bad excuse. Three of my top students were girls, and the guys had a real lot of respect for them. There are just as many guys today who are clueless about the machines they trust to get them back home.
White smoke is a sign of burning engine coolant. You will observe you need to add coolant periodically. The cause is almost always a leaking cylinder head gasket, but it is possible to have cracked cylinder head. There are two tests to confirm this. The first is perform a chemical test at the radiator with the engine running. Air is drawn through a glass cylinder with two chambers partially-filled with a special dark blue liquid. If combustion gases are present, the liquid will turn bright yellow. This test takes just a few minutes. It's much less expensive to have your mechanic do it than it is to buy the tester and fluid.
If that test comes up negative, you can add a small bottle of dark purple dye to the coolant, then search a day later with a black light. The dye will show up as a bright yellow stain that you can follow back to the source. If the head gasket is leaking, you will find the dye inside the tail pipe. Auto parts stores will have the dye for the fluid being tested, and those that rent or borrow tools should have a black light.
Dec 13, 2017 at 6:59 AM
HELENG
Thanks for the response, also i never said a women could not i was implying that me as a woman who is profession is to teach kids has no idea what is what when it comes to cars. I apologize if it came out that way. But thanks anyway this was very informative.
Dec 13, 2017 at 7:06 AM
CARADIODOC
  • 34,414 POSTS
I was a teacher too.
Please post a reply when you have a solution.
Dec 13, 2017 at 9:59 AM
