Smoke coming out of exhaust more than normal?
220,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
JEEP769
  • 51 POSTS
I have the truck listed above 1500. It uses a little bit of oil I'd say about a quart every two weeks or so and it all the sudden started smoking more out of my exhaust seems to be a white smoke not for sure what to check. any ideas would be helpful. thanks
Dec 27, 2024 at 7:16 AM
  • 110,244 POSTS
White smoke from the exhaust can often indicate a failed head gasket. If engine coolant enters the combustion chamber, it will produce white smoke.
Please do me a favor, look through this link and let me know if anything mirrors what you are experiencing:
https://www.2carpros.com/articles/recognizing-the-symptoms-understanding-a-blown-head-gasket-in-your-vehicle
Dec 28, 2024 at 1:06 PM
JEEP769
  • 51 POSTS
Yeah, that did help me out did help me out. I do not have any coolant leaking anywhere externally that I can see. and my engine oil looks fine so I'm thinking it is just a slight leak.
Dec 31, 2024 at 6:28 AM
  • 55,512 POSTS
Did you try a pressure tester? This guide can help you find the leak, use a flashlight and check the bottom of the water pump and the radiator. With the steam though it might be a head gasket.
And go over this guide as well:
https://www.2carpros.com/articles/car-is-leaking-coolant
Please upload pictures or videos in your response of any problems so we can see what to help you with.
Jan 3, 2025 at 3:20 AM
JEEP769
  • 51 POSTS
Okay, i don't have a pressure tester but i am taking it to a local mechanic now that you've helped me narrow it down. Thanks for the info and your time.
Matt
Jan 4, 2025 at 12:50 AM
  • 55,512 POSTS
Hi Matt,
You can rent one form the auto part store for cheap or free, but let me know what the repair shop says, I am interested.
Jan 4, 2025 at 3:21 AM
