Smoke coming from driver's side of the engine
112,000 MILES • 4.3L • V8 • 2WD • AUTOMATIC
BOBBYMO21
Had it running for about 15 minutes this morning and I noticed some smoke coming from the left (drivers) side of the engine. I also lose coolant from my reservoir overflow. I'm wondering if a bad water pump could be the cause. I know these engines are known for the gasket/bolt problems, but I'm trying to eliminate all other possibilities before diving into that one.
Feb 12, 2021 at 9:09 PM
  • 110,248 POSTS
If you are losing coolant, chances are it is a hose. Here is what I suggest. Open the hood and start the engine. See if you can tell approx where the smoke is coming from. Do that and let me know.
Here is a link that you may find helpful with the coolant leak:
https://www.2carpros.com/articles/car-is-leaking-coolant
If you can get a pic of where the smoke is coming from and upload it, it will help me.
Take care and God Bless,
Feb 13, 2021 at 11:44 AM
