My car smokes during acceleration it is a bluish smoke
113,478 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
NICKRAVETT2663
I change my PCV valve my intake manifold gaskets and my spark plugs and my valve cover gaskets and also did an oil change and my car is still continuing to smoke during acceleration. It is a bluish smoke and my water levels have not gone down, but it is continuing to lose oil and there are no leaks, but my exhaust pipe is full of burnt oil? I really do not know where to go from here. is there any kind of temporary fix to get me home? I am two hours away from the house and scared to drive it.
Oct 11, 2016 at 12:37 AM
HMAC300
  • 48,601 POSTS
it may be a broken ring or valve seals bad causing that, it still could be a head gasket as well depending on how fast the oil goes down. or it could be a leak from oil pressure switch as well. the internal stuff you cannot do much about if you are driving home just keep oil level up where it does not go below two quarts and drive. check oil pressure switch as that is an easy thing and you should be able to see it. switch is on lower left rear of engine.
Oct 11, 2016 at 5:05 AM
