Smelling oil through the vents
88,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
DAVID CADDICK
The smell of oil in the cabin when I am on my journey, it only smells some times. is there a pipe going from the engine which some how by passes that there could b a split? I just had a new engine fitted it's booked in for a oil & filter change which is done every 6k
Aug 8, 2016 at 4:22 AM
SATURNTECH9
  • 30,868 POSTS
Sounds like you have a oil leak on your engine like a valve cover here is a guide to help you find it.
https://www.2carpros.com/articles/engine-is-leaking-oil
and
https://www.2carpros.com/articles/replace-valve-cover-gasket
Check out the diagrams (Below)
Cheers
Aug 8, 2016 at 5:15 AM
DAVID CADDICK
Thanks you were right it was the valve cover leaking it cost me 14.59 for the gasket but now no more leak thanks for you help the guides did great.
Aug 12, 2016 at 5:05 AM
