small metal balls found in front differential (possible ball bearings)
80,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
01JEEPGC
  • 10 POSTS
When I changed my differential oil in my Dana 30, veri-loc front axle in my 2001 Jeep Grand Cherokee with quadra-drive, there was just normal metal shavings on the magnet but in the bottom of the pumpkin I found several very small metal balls, maybe ball bearings but have never seen any this small on any vehicle, what could they be and is this serious? The pic is the balls on the fill plug magnet, and the magnet is less than 1" so you can see how small these are.
Mar 23, 2014 at 2:58 AM
HMAC300
  • 48,601 POSTS
it cold be small pieces of metal coming off of the clutch plates inside which I've pointed to in the pic. I really wouldn't worry about it to much , the car is 13 yrs old an is going ot have some wear. As long as it continues to operate ok and not make any noises let it go. or drive it til it breaks which may be years from now.
Mar 23, 2014 at 3:14 AM
01JEEPGC
  • 10 POSTS
These little round balls could be coming off a clutch plate? Not doubting you but how could they be round? These are not slivers, they are round.
Mar 23, 2014 at 6:48 AM
HMAC300
  • 48,601 POSTS
that is the only thing I can think of as the clutch plates that I pointed to are steel and from wear they may begetting worn round andfall off or they are getting mashed in the gears because they are small it won't hurt it to much. If it were bearing material they are very hard and when they go bad they peel off, kinda like chrome peeling if you have ever seen that. regardless I don't think it is something to be worried over and just drive it.
Mar 23, 2014 at 8:44 AM
CJ MEDEVAC
  • 11,000 POSTS
YOUR PIC NEVER ARRIVED
MY HYPOTHESIS IS THE BALLS ARE "CAST IRON SPLATTER" FROM THE CAST IRON CASE BEING POURED
ALL OF THIS CRAP GOES THRU WASHED, ETC TO CLEAN 'EM UP AFTER THEY ARE CAST
SOMETIMES THE SPLATTERS ARE SORTA WELDED/ STUCK TO THE CASE INSIDE AND OUT......DRIVING HEAT (EXPANSION / CONTRACTION)/ BOUNCING/ GEAR OIL FLOW AS THE GUTS TURN INSIDE MAY HAVE DISLODGED THE ONES YOU SEE------HECK, THERE MAYBE OTHERS "STUCK GOOD" STILL ON THE CASE
SEE-UNS HOW YOU HAVE POSITIVE TRACTION W/ CLUTCH PACKS.....I FEEL SURE YOU WILL REQUIRE SOME KINDA "FRICTION MODIFIER" ADDITIVE TO GO ALONG WITH THE GEAR OIL (SOMETIMES IT COMES IN A BIG OLE TOOTHPASTE TUBE AND MAY TREAT UP TO TWO QUARTS OF GEAR OIL....DO YOUR HOMEWORK!)
-----MAKE SURE YOU PUT THE RIGHT STUFF IN AND IN THE CORRECT AMOUNT !!!!!------IF YOU DON'T THE CLUTCHES WEAR AWAY AND YOU WILL GET MEGA SLOP IN THE ROTATION OF YOUR PINION YOKE (LIKE A 1/4 TURN BEFORE IT CATCHES THE RING TO MOVE (FWD TO REV)
I, MYSELF, TRUST SHOWN/ SEEING THE SPECS IN WRITING......NOT FRED YELLING TO MIKE, ACROSS THE STORE, "HOW MUCH ADDITIVE DOES THIS FELLER NEED?"
HERE'S A PIC OF A REAL EZ WAY TO INSTALL YOUR GEAR OIL.....THE PUMP IS LESS THAN $5 AT A PARTS STORE
WHEN THE FLUID LEVEL REACHES THE FILL HOLE (ON LEVEL GROUND) AND STARTS RUNNING OUT--GIVE IT TWO QUICK PUMPS AND STICK THE PLUG BACK IN FAST!.............DIGGING IN THE HOLE WITH YOUR PINKY FINGER DON'T CUT IT FOR CORRECT LEVEL......CORRECT LEVEL IS WHEN YOU PULL THE PLUG OUT FOR A "LOOK SEE" AND THE FLUID "JUST STARTS TO FLOW OUT!"
KEEP US POSTED
THE MEDIC
Mar 23, 2014 at 11:14 AM
01JEEPGC
  • 10 POSTS
I will try to attach pic again. If these are clutch plat fragments is this why the front diff. (this Dana 30 veri-loc) going straight down the road is pretty quiet but turning a corner, the sharper I turn the more noise/grawling noise it makes, and in 4wd it's even louder, is this the clutch plates breaking down? Does the axle need rebuilding when this happens or just part of the breakdown/wear out process?
And for the additive, can a extra hurt anything? I use the Redline that says it made for the quadra-drive axles/system, that's what I have and Redline says they have their own limited slip additive and you don't need to add any but I still put the recommended amount ~2 oz of the Chrystler additive made for the Dana 30 veri-loc, several people told me Redline is the best for the QD system but you still need to put the Chrystler additive in...any comments on this?
Mar 24, 2014 at 9:46 AM
HMAC300
  • 48,601 POSTS
I still th ink it is the cast that the medic talks about or the plates breaking down. as far as making noise your clutch plaltes are sticking but the additive should stop that from doing it unless they are locked together that would be your noisethe 2 oz won't hurt a thing it'snot enough to make it overflow. but the sticking plates is why the noise as they stick then release then stick so it will growl like. Won'thurt anything just noisy so you might try another bottle of additive to see if that helps it.
Mar 24, 2014 at 10:58 PM
CJ MEDEVAC
  • 11,000 POSTS
THIS INFO IN MY LINK MIGHT HELP TOO
SEE MY ANSWER IN THIS
https://www.2carpros.com/questions/2006-dodge-ram-clunking-noise-rear-differential-axle-turning-right-put-gear
KEEP US POSTED ON YOUR SITUATION
THE MEDIC
Mar 25, 2014 at 9:21 AM
01JEEPGC
  • 10 POSTS
Medic
I read your other post you linked above, funny the front I just changed the oil in, if you spin one wheel the other does go in the same direction, but getting this WJ checked by a local shop they told me..."you don't have veri-loc or any type of posi as when they had it up they spin one rear and the other they said moved the opposite way but when I get on it a bit off road it kicks from both rear wheels, I don't understand, what gives?
Mar 27, 2014 at 9:38 AM
CJ MEDEVAC
  • 11,000 POSTS
A STANDARD DIFF WILL "PULL" WITH BOTH WHEELS ON FIRM AND HARD SURFACES
YOU CAN EVEN DO A BURNOUT.....AS LONG AS THE FRICTION ON THE GROUND REMAINS EQUAL OR CLOSE TO EQUAL
LETS SAY DURING YOUR BURN OUT, YOU LURCH FORWARD INTO SOME SAND ON THE ROAD.........THE WHEEL IN THE SAND IS GONNA SPIN FASTER DUE TO LOSS OF TRACTION.........THE OTHER WHEEL IS GONNA SLOW DOWN OR EVEN STOP......BECAUSE IT HAS TRACTION
THE SAME IS GONNA APPLY IN MUD......WHEN ONE STARTS SPINNING, THAT'S IT!!!!......YOU ARE STUCK!!!!...........UNLESS YOU ARE IN 4X4 AND THE FRONT WHEELS PULL YOU OUT, OR UNTIL YOUR REAR GAINS TRACTION ON BOTH SIDES
EXTREME!!!.....MAYBE NOT TOO EXTREME.......ONE WHEEL ON THE FRONT SPINS AND ONE IN THE REAR SPINS........YOU ARE REALLY STUCK!.............TIME FOR THE WINCH!
AS FAR AS POSI-TRACTION/ LIMITED SLIP/ LOCKERS............BOTH WHEEL HAVE EQUAL TRACTION (MOST OF THE TIME) IF ONE WHEEL IS IN THE MUD.....IT WILL NOT SPIN AND THE OTHER SIT STILL......NO NO NO ! BOTH WHEELS WILL CONTINUE TO TURN FORWARD (OR BOTH REARWARD) .......AS LONG AS EITHER WHEEL HAS TRACTION OF SOME SORT.....IT WILL CONTINUE TO GO!
THE "LIMITED SLIP" PART MEANS THE THE CLUTCHES (OR OTHER MEANS) WILL LET THE AXLE (LEFT AND RIGHT) SORTA......BREAK LOOSE/ SLIP/ UNLOCK SO THAT YOUR VEHICLE CAN MAKE TURNS----WITHOUT "DRAGGING" THE WHEEL THAT HAS TO TRAVEL THE LONGEST DISTANCE DURING THE TURN
THE "DRAGGING ACTION" IS WHAT INSPIRED SOMEONE TO COME UP WITH THE "DIFFERENTIAL IDEA" (THE STANDARD TYPE) IN THE 1ST PLACE------BOTH WHEELS CAN BE UNDER POWER WHILE TURNING WITH NO DRAGGING
THIS IS OLD.......I SAW THIS IN HIGH SCHOOL AUTO SHOP (IT WAS OLD THEN TOO).......BACK IN 1979 ON A REEL TO REEL PROJECTOR......YOU KNOW, THE ONES THAT WOULD GO HAYWIRE AND CLACK-CLACK-CLACK-CLACK!!! TILL SOMEBODY PUNCHED THE BUTTON TO GET THE FILM BACK ON TRACK
http://www.youtube.com/watch?v=yYAw79386WI
IT REALLY MAKES YOU UNDERSTAND THE "STANDARD DIFF".....IN ONE SITTING!..............YOUR RIDING LAWN MOWER WILL EXHIBIT THE SAME SYMPTOMS AS YOUR CAR
I'M SURE THERE ARE OTHER VIDEOS ON YOU TUBE THAT MIGHT EXPLAIN THE LIMITED SLIP STUFF BETTER THAN ME (BUT I DO UNDERSTAND 'EM!)
THE OLE DIRT TRACK RACE CAR DRIVERS SIMPLY TAKE OFF THE BACK COVER OF THE DIFF AND WELD ALL OF THE GEARS TOGETHER SO THEY WON'T MOVE (PUT THE COVER PACK ON AND REFILL WITH GEAR OIL) THIS GIVES THEM 100% POSI-TRACTION.........BUT NOW THEY "DRAG" THE OPPOSITE WHEEL WHEN THEY TURN.....IT'S DIRT!....IT'LL DRAG WITH NO PROBLEM!
ANY BETTER?
THE MEDIC
Mar 27, 2014 at 10:58 AM
01JEEPGC
  • 10 POSTS
hummm...interesting but still don't understand, this WJ Grand Cherokee Limited is supposed to have the Dana veri-loc axles, 30 front, 44 rear which is supposed to be some type of posi axles and sought after by the guys on the Jeep forums. Which I have been told the clutch plates is what is making the noise when turning...I will have do some reading on these.
Mar 27, 2014 at 11:09 AM
