Small jerking when i shift gear R anr D?
64,000 MILES • 4.2L • V8 • 4WD • AUTOMATIC
EMO556
Small jerking comes when i shift the gear R & D, For this problem i change spark plug,Ignition coil,injector wash, intake manifold seal and the last i overhaul full engine with fin new valve and valve seal and head gasket, and change also engine and transmission mount,
Still i have this problem
Mar 14, 2026 at 4:36 AM
  • 55,685 POSTS
Can I ask if you have 64k miles on this vehicle? Also, does the noise come from the front mid or rear of the car, can you upload a short video of the issue? I have seen loose rear left springs cause this issue, you can have a helper watch under the car as you put the transmission in drive and then reverse to help confirm the play in the drivetrain. I would try tightening the rear leave spring U bolts. Also, note how much the drive line rotates once the transmission in moved from drive to reverse. Let me know, Ken
Mar 16, 2026 at 2:25 AM
