Small evap leak
55,000 MILES • 4.0L • 6 CYL • 4WD • MANUAL
KARCHERFAMILY
Small evap leak code.
New gas cap and the purge valve by the engine. A friends smoke test supposedly shows a tiny leak in the fuel tank, where the white plastic filler tube fitting goes on the black poly tank. As if the seal between them failed. Isn’t that a heat sealed part, with no gasket? I don’t have a smoke machine. How do I test, confirm and repair? Thank you.
Sep 16, 2020 at 11:29 AM
  • 110,248 POSTS
I attached a pic below and highlighted what I believe to be what you are referring to. Please confirm.
If that is it, there is no seal that I have ever seen.
Let me know if that is where you mean.
Sep 16, 2020 at 11:40 AM
