Sluggish no power?
200,000 MILES • 4.2L • V6 • 2WD • AUTOMATIC
TONYLL
  • 10 POSTS
Starts and runs. Once it warms upon acceleration acts like it has no power at normal take off. But can give it a lot of throttle and will it will go. And about every 3 or 4 weeks it will foul out plugs 1,2, and 3 on passenger side.
Aug 19, 2025 at 11:01 PM
  • 55,710 POSTS
Yep, this is telling us you may have a catalytic converter on the that is clogged on the passenger side. Here is a guide to help test it to help confirm the issue.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
You may have a fuel pressure regulator that has gone bad, I would remove the vacuum line to see if there is fuel present and if so replace the regulator. Here is the location in the images below, also I would scan the truck for codes and go over these guides as well.
and
https://www.2carpros.com/articles/engine-has-low-power-output
Please upload pictures or videos in your response of any problems so we can see what to help you with.
Aug 20, 2025 at 6:04 AM
