Sluggish when accelerating from a stop
83,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
MIKEBRY
My car idles fine but when I take off it is sluggish and I have a “sweet” spot I have to stay in. If I give it too much gas it acts like it has no power. Sitting in park or on the road if I rev the engine up to around 3800 or 4000 rpm's the engine will cut out. Not shut off but will not go any higher rpm's. Please help. Thanks
Jan 5, 2018 at 9:46 AM
Good morning.
Some possibilities:
Low fuel pressure.
Catalytic converter clogged.
EGR valve partially open.
Injectors.
Worn timing chain.
Is the check engine light on?
Jan 5, 2018 at 8:30 PM
MIKEBRY
Yes, I had it checked and it indicated multiple misfires, 02 sensor and the purge valve. I checked the plugs and wires and all is good there. Checked the hoses going to the purge valve and they look okay. Have not replaced the o2 sensor yet.
Jan 5, 2018 at 9:42 PM
Okay, do not change the O2 sensor. it is not the issue.
Start with fuel pressure test for low pressure. It would explain the misfire codes and sluggish running.
Jan 5, 2018 at 9:44 PM
MIKEBRY
Okay, thanks. I will let you know the outcome when I get it checked.
Jan 5, 2018 at 9:47 PM
You are welcome. Keep us updated.
Jan 5, 2018 at 9:50 PM
