Sludge in coolant reservoir?
111,111 MILES • 4.0L • AUTOMATIC
ARIANADANIELLE5345
  • 402 POSTS
There’s thick black sludge in coolant reservoir that doesn’t smell like oil. Opened radiator cap and coolant is fine so oil on top of water or anything. Car never overheats but oil pressure is closer to high on the instrument cluster gauge.
Sep 10, 2025 at 12:07 PM
  • 55,688 POSTS
So what happens is the transmission cooler inside the radiator goes bad and pushed transmission fluid inside of the engines cooling system, please go over this guide to see what I am talking about:
https://www.2carpros.com/articles/transmission-fluid-in-radiator-coolant-reservoir
You will need to replace the radiator and flush the cooling system.
Sep 11, 2025 at 3:18 AM
ARIANADANIELLE5345
  • 402 POSTS
And the cooler?
Sep 12, 2025 at 8:15 AM
ARIANADANIELLE5345
  • 402 POSTS
Or did you mean replace cooler and flush cooling system?
Sep 12, 2025 at 8:16 AM
ARIANADANIELLE5345
  • 402 POSTS
Or replace radiator and cooler?
Sep 12, 2025 at 3:27 PM
  • 55,688 POSTS
The cooler is inside the radiator, so just replace the radiator.
Sep 14, 2025 at 3:25 AM
ARIANADANIELLE5345
  • 402 POSTS
It isn’t inside on this one though. It has a radiator and a separate transmission cooler.
Sep 17, 2025 at 2:35 AM
ARIANADANIELLE5345
  • 402 POSTS
Here’s a pic. At least I’m assuming that’s what that is.
Sep 17, 2025 at 2:42 AM
  • 55,688 POSTS
Hmm, does it have transmission cooling lines going into the radiator?
Sep 17, 2025 at 2:45 AM
ARIANADANIELLE5345
  • 402 POSTS
lol never mind it’s A/C condenser.
ARIANADANIELLE5345
  • 402 POSTS
She said she just had the radiator replaced not too long ago so I’m thinking that maybe they didn’t change the reservoir and that’s why the radiator wasn’t that dirty but the reservoir is full of gunk.
Sep 17, 2025 at 2:47 AM
ARIANADANIELLE5345
  • 402 POSTS
Can I submerge the radiator and put my compressor on the transmission cooler line and check for bubbles to see if it’s leaking internally? Or would that not work or could that possibly mess up the trans cooler part?
Sep 17, 2025 at 2:56 AM
  • 55,688 POSTS
That could be that is was left over from the pervious repair, you cannot submerge the radiator and look for leak, sorry.
Sep 17, 2025 at 9:37 AM
ARIANADANIELLE5345
  • 402 POSTS
How do I flush the system?
Sep 18, 2025 at 11:41 AM
  • 55,688 POSTS
Dump and fill several times is your best bet, here is a guide to help you:
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Once the system is empty, pour more hot water through it to help get the sludge out. Also, before you begin try to use a turkey baster to suck as much as you can off of the top. Let us know how it goes.
Sep 19, 2025 at 12:42 AM
ARIANADANIELLE5345
  • 402 POSTS
Do I need to flush the transmission also?
Sep 19, 2025 at 6:49 AM
  • 55,688 POSTS
That would be a good idea as well, yes. good call
Sep 19, 2025 at 9:58 AM
ARIANADANIELLE5345
  • 402 POSTS
A trans flush won’t damage it since it has a lot mileage on it?
Sep 28, 2025 at 12:57 AM
ARIANADANIELLE5345
  • 402 POSTS
And the trans fluid isn’t pink, so does that mean there’s no coolant in it? Looks dirty but not pink.
Sep 28, 2025 at 12:58 AM
  • 55,688 POSTS
It looks like it needs to be changed, it is tough to tell if there is coolant in there.
Sep 28, 2025 at 3:59 AM
ARIANADANIELLE5345
  • 402 POSTS
I tried to ask a question about an oil pump and It was there for like a day but now it’s gone. Should I redo it? Or is it just my browser or something
Oct 7, 2025 at 11:04 AM
STEVE W.
  • 15,403 POSTS
Best would be to log in and ask it again, there have been a few site issues lately.
https://www.2carpros.com/questions/new Thank you.
Oct 8, 2025 at 2:18 PM
