Slow pickup and transmission shifting?
200,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
ERVINW
  • 5 POSTS
Seems to be not changing the gears quickly at about 50km and sometimes after braking, the pickup may be a bit slow. I have cleaned the throttle body and the Mass Air Flow Sensor. There are no check engine lights or codes.(Nissan Bluebird Sylphy 2007)
May 15, 2024 at 1:39 AM
  • 55,688 POSTS
This can happen when the catalytic converter starts to clog up and lower engine vacuum making the engine computer think the car is going up a hill which holds the gears longer. This guide can help confirm the issue:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Also, we should run the codes to see if any are stored.
Please go over these guides and get back to us.
May 16, 2024 at 5:16 AM
ERVINW
  • 5 POSTS
Sorry about the tardy response, I will try these as soon as the weather permits and provide feedback. I only have weekends available.
May 20, 2024 at 5:32 AM
  • 55,688 POSTS
No worries, let me know how things go.
May 20, 2024 at 5:47 AM
ERVINW
  • 5 POSTS
Good morning Ken, Finally got around to checking it, i disconnected the catalytic converter and washed it with soap water allowed it to drain before installing it. the problem has subsided. I will reset the throttle valve hopefully this weekend and allow it to relearn.
Thank you so much.
Oct 21, 2024 at 9:33 PM
  • 55,688 POSTS
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Oct 22, 2024 at 3:32 AM
