slow cranking when hot
230,000 MILES • 1.6L • 4 CYL • FWD • AUTOMATIC
TRACKMAN2479
This happened after I installed a rebuilt head. When the car is cold it cranks fast and starts up perfectly. After driving and letting car warm up well, then when I turn off and try to start it will crank very slowly and erratic. I replaced the starter, ground wires and new cable too starter. I am thinking something in that rebuilt head expands when hot causing some tightness? Well I would appreciate any help you can give me. Thank you Ken.
Aug 24, 2017 at 1:08 PM
  • 55,721 POSTS
Yes, it does sounds like the cylinder head is binding up. this can happen if the head has torqued unevenly. I would recheck the torque first.
Here is a video that shows how to use a torque wrench:
https://youtu.be/juOClONIWeY
Please let us know what you find.
Cheers, Ken
Aug 25, 2017 at 6:07 AM
