Slow crank when very cold
39,700 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
NEIL2002CIVIC
  • 119 POSTS
Hi, my car cranks or sounds like it's cranking slow when very cold out, but does start (no jump start required). It has the PZEV emissions so it has the bigger battery 600cca. How can I check the starter volt meter or do I need special equipment? Are there any bulletins on this problem? Thanks Neil
Battery replaced 2015.
Mar 4, 2019 at 5:24 AM
  • 110,248 POSTS
I'm not sure how cold it is where you are located, but once the temperature reaches freezing, the average battery will lose between 35 and 40% of it's cranking ability and the colder temperatures demand more current to start the car. Most parts stores will load test a battery for free with hopes of selling you a new battery. If you want to check it yourself to see if the voltage level is maintained, take a volt meter and connect it to the battery. You should see 12+ volts with the engine off and all power accessories off. Next, have a helper crank the vehicle while you watch the volt meter. If the reading goes below 9.6 volts while cranking, replace the battery.
Also, a dirty or corroded battery terminal can also magnify the problem. Any added resistance between the battery terminal and battery reduces power. I have actually seen loose or dirty cables lose connection in cold weather causing a no start. Once everything was cleaned and tightened, all was good again.
Here are a couple links you may find helpful. Take a look through them and see if they help.
https://www.2carpros.com/articles/symptoms-of-a-bad-car-battery
Mar 4, 2019 at 11:04 AM
NEIL2002CIVIC
  • 119 POSTS
I will need a new battery thanks for your help i asked another question also
Mar 13, 2019 at 11:07 AM
  • 110,248 POSTS
Not a problem. Let me know if I can help.
Mar 13, 2019 at 2:30 PM
