Slipping unless overdrive is off
100,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
ARIANADANIELLE5345
  • 402 POSTS
Truck slips at about 3,000 RPMs unless overdrive is off. Could this be the OD band or shift solenoid or something completely different?
Jun 4, 2022 at 9:01 PM
This could be the overdrive band, but we need to find out a little more info as to when this slips.
Can you put it in manual 2 and leave the OD on and see if it slips.
If it still slips, then this could be the intermediate clutch or the overdrive. So that means we need to put it in drive with OD still on and see if when in 2nd gear at this RPM it slips. If it does in 2nd with OD on, then this is most likely the intermediate clutch that is slipping.
Also, we should check the fluid level and condition before we do anything just to be sure that is correct.
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
If you look at the attached info, the overdrive band is only applied in 2 manual and 4 overdrive.
So, we need to try and find out if the slipping only occurs in these gears to narrow down what this could be.
Let me know if you have questions on this. Thanks
Jun 5, 2022 at 11:57 PM
ARIANADANIELLE5345
  • 402 POSTS
I already dropped the pan and pulled the valve body, so I can’t test it, but i know when overdrive is off it’s fine. When overdrive is on, and it gets to 3,000 RPMs the gas pedal gives and the speedometer increases without the car actually going any faster. The rpm doesn’t move though. When checking the valves, I noticed they all bounced back when I pushed them into their springs except for one. One got stuck. Other than that, all the check balls were the right size and in the right spot. Everything looked okay except it really needed the fluid changed. The separator plate also had little pieces of the black coating or paint or whatever is on it chipped off.
Jun 6, 2022 at 9:07 AM
Can you get a picture of the separator plate if you have not already put it back together? I think I know what you are talking about and that is most likely fine but seeing it will help.
Also, when you say the valves, are you talking about the valves in the valve body? If you have one that is sticking, then that is an issue. They should move pretty easily.
Can you remove the overdrive servo and see if you can get a look at the drum where the band rides? I bet it will look really shiny which means it is most likely slipping and not holding.
Jun 6, 2022 at 9:31 AM
ARIANADANIELLE5345
  • 402 POSTS
The red arrow is the one that’s sticking and not springing back out and the red rectangle is where the thing in my hand came out of.
Jun 6, 2022 at 10:26 AM
ARIANADANIELLE5345
  • 402 POSTS
And the second pic is the black stuff that chipped off. Actually, when I went to pick it up to take the pic it started peeling off.
Jun 6, 2022 at 10:27 AM
ARIANADANIELLE5345
  • 402 POSTS
Here’s a video from under the car.
Jun 6, 2022 at 11:24 AM
Got it. Yeah, that black plate needs to be replaced if it is that bad.
Sometimes the edges start to chip but if there is a crack in it then it needs to be replaced or you can have a fluid leak that will bleed off pressure. That black part is actually the separator plate gasket. There should be one on either side. See below for details.
If that valve is stuck then that could be the issue. That is the bypass valve and is used to control pressure and fluid flow. I am attaching info below on that.
Basically, there is either debris or build up on the valve or in the bore. So, take some Emory Cloth or steel wool and lightly sand it down so that the valve slides in and out smoothly.
The piece in your hand is the control valve plate that holds the valve in.
Let me know if you have questions with this.
Jun 6, 2022 at 12:23 PM
ARIANADANIELLE5345
  • 402 POSTS
Perfect, thank you! Someone else told me I was going to need a complete overhaul, but I didn’t understand why because there were no flakes or chunks of metal in the pan or valve body. The fluid was just really dirty. So, I figured I should come on this website and get a second opinion because this website is the only place that has never steered me in the wrong direction. If you guys don’t know the answer to my question, then you take the time and try really hard to figure it out, which I appreciate more than you know. Thanks again!
Jun 6, 2022 at 4:17 PM
ARIANADANIELLE5345
  • 402 POSTS
Actually, I do have a couple more questions. The first picture is of what fell out of my transmission onto the floor when I pulled the valve body off. Is it bad that that stuff fell out? If not, then what are those where do they go? Also, the second picture is of one of the little circular plates that goes on the valve body. I was told since I took them off, I would have to replace them or else they would leak. Is that true?
Jun 7, 2022 at 12:26 AM
ARIANADANIELLE5345
  • 402 POSTS
Also, I don’t need a new separator plate, right? Just the gaskets?
Jun 7, 2022 at 1:57 AM
Yes. The separator plate can be reused. Gaskets need to be replaced.
If the fluid was really dirty, then this is why they are saying you need to rebuild the unit. Any time you have slipping and dirty fluid that means it has been doing it for a while and it is safer to rebuild the whole unit while you are there.
You may get more life out of this unit but based on what I am seeing, you may need a rebuild but this may fix the issue in the short term. If I were doing it, I would rebuild it but that is because I have done a lot of these units and they are not too bad, but it is a lot of work.
If you take a look at the picture below. Number 1 is the solenoid screen
Number 2 is a converter drain back valve.
Number 3 I am not sure about. That looks like a cotter pin, but I am not sure where that goes.
Take a look at the attachments above of the exploded view of the valve body to show where they go.
Lastly for the plates, I don't remember having to replace them unless there is an issue.
Jun 7, 2022 at 4:06 AM
ARIANADANIELLE5345
  • 402 POSTS
Okay, and what can I use to clean everything? Just compressed air or is there a cleaner?
Jun 7, 2022 at 5:10 AM
ARIANADANIELLE5345
  • 402 POSTS
The owner of the car said as long as it lasts like a year, so he can save up for a new car, then he’s okay with just changing the fluid and gaskets. And whatever was stuck isn't stuck anymore. I looked at it this morning and they all move freely now. I don’t need to change anything else, right? since there were no metal prices or anything, right? That cotter pin worries me though because I don’t know where it came from all I know is it dropped when I took the valve body off.
Jun 7, 2022 at 5:27 AM
ARIANADANIELLE5345
  • 402 POSTS
The fluid was really dark and this is what the magnet looked like:
Jun 7, 2022 at 5:29 AM
ARIANADANIELLE5345
  • 402 POSTS
Are these spots, okay? I can’t get them off.
Jun 7, 2022 at 10:00 AM
Sorry for the delay. The spots are fine. That is pretty typical on those.
You can clean everything with parts cleaner spray. Just make sure you give everything time to evaporate.
Then soak any rubber seals in transmission fluid if you are replacing them. This just prevents any tearing when installing them into a bore. However, I am not sure you have any of these because you are just dropping the valve body.
I cannot think of any other parts that you will have to replace at this point, but we are going to have to test drive it once it is back together.
If the fluid was really dark and that much metal on the magnet then when you put new fluid in it, the clutches may not like it.
There is a myth that if you change old fluid that you are going to have a failure but that is based in some truth. Basically, what happens is when the clutches are damaged to the point that there is metal going through them then this grit actually helps apply the clutches, but it also damages them further. When you flush this out the now damaged clutches have nothing left to grab each other when they are applied and so it starts slipping.
Basically, I would just finish with what you are doing but prep the owner that we have to test drive it in order to make sure there are no other issues. However, you have no way of avoiding them. You can't do all this and not change the fluid or risk this from happening.
Jun 8, 2022 at 9:30 AM
ARIANA NELSON
So, change the fluid, right? Because I already dumped the old fluid. Will it likely last a year? Or is there no way of telling? There’s should still be some of the old fluid left in the transmission because I only emptied the pan.
Jun 8, 2022 at 10:00 AM
ARIANA NELSON
I don’t need to check the overdrive band or anything? I don't know where that is but I’m sure I could figure it out if I need to. Should I test valve body and solenoids too? I don’t have a vacuum to test the valve body, but I do have a multi meter and an Autel scanner which didn’t pick up anything wrong with the transmission for some reason. Must mean solenoids are fine? I don’t know.
Jun 8, 2022 at 10:01 AM
You have changed what you can from what you have removed.
The next step is, we need to remove the transmission. In order to change the band, we would need to disassemble the unit. Clearly that may be needed but if you are not wanting to do a full rebuild then I am not sure anything is possible.
Yes. Change the fluid. Even if you had the old fluid, I would still recommend changing the fluid.
Jun 8, 2022 at 10:04 AM
ARIANA NELSON
I tried to sign in because I thought I usually sign in through Facebook, but I think I may have just made another account on accident. Sorry lol
Jun 8, 2022 at 10:05 AM
ARIANA NELSON
What about this? This is where one of the circular plates go. I took pics at two different angles so that hopefully you can see that it’s indented slightly.
Jun 8, 2022 at 10:47 AM
Yeah. I have seen that before and never known it to cause an issue.
If you would sleep better at night, then I would replace it but otherwise I think it is fine.
Jun 8, 2022 at 11:32 AM
ARIANADANIELLE5345
  • 402 POSTS
Can I reuse the check balls? None of them look like they’re worn. They’re all the same size.
Jun 8, 2022 at 11:40 AM
ARIANADANIELLE5345
  • 402 POSTS
I think I found out what that indent was that’s located near where the small circular plate goes. It’s made by the manufacturer to keep the plate from flexing and cracking. It’s only located in that spot, on models 2000 and up according to a video I watched of a mechanic rebuilding the valve body. He said if there are small pressure cracks right there then you need to replace the plate because eventually with more pressure the cracks will get larger.
Jun 8, 2022 at 1:57 PM
ARIANADANIELLE5345
  • 402 POSTS
Can I use this on the transmission oil pan? It’s what came up when I input the vehicle info, but it looks a lot different than the original. Holes line up though.
Jun 9, 2022 at 5:18 AM
Okay. That is great info. Thanks for sharing that which explains why I have seen them before, but I didn't know that. Thanks
As for the check balls. Yes, you can absolutely reuse them.
ARIANADANIELLE5345
  • 402 POSTS
Or is the original reusable?
Jun 9, 2022 at 5:27 AM
You mean is the oil pan gasket reusable?
The only reusable gaskets are the hard rubber/plastic ones that are in good condition. Cork, paper, bendable rubber gaskets are not able to be reused.
I don't think this pan came with the hard plastic/rubber ones, so you need to use a new one.
You can get a gasket in any type of material for most any pan so you can pick the one you want to use.
Jun 9, 2022 at 7:04 AM
ARIANADANIELLE5345
  • 402 POSTS
The original is hard rubber, but I can't tell if it’s in the best condition. The new gasket is way thinner, but is it still okay to use? Okay cool. That works for me, lol.
Jun 9, 2022 at 7:32 AM
ARIANADANIELLE5345
  • 402 POSTS
Okay, so change of plans. I went to the Ford dealership to ask the service guys some questions. They told me that the cotter pin looking thing goes in between teeth on clutches or something like that and without it it’s going to clunk really loud, and it’s caused by a worn transfer case. And they also said all that sludge on the magnet means the torque converter is going bad so that means a rebuild. Complete rebuild. So, would you happen to have the instructions on that along with a complete parts list? And will I need any special tools? Or should I ask this stuff in a new question?
Jun 9, 2022 at 10:15 AM
While you may have been okay, I think this is the best course of action. Especially now that you know where that piece of metal came from.
Yes. Let's get a new post started asking for rebuild instructions. That is really good info that we want to make sure all others in the future are able to find.
Thanks for your understanding and sticking with us. I am sure you will be happy with the results after the rebuild.
Thanks
Jun 10, 2022 at 12:40 AM
