Slipping transmission
92,000 MILES • 4 CYL
BOB OSBORNE
Around 40 to 45 mph transmission will slip, not all the time but sometimes. It's an automatic but when it acts up it acts like a manual whereas it acts like it down shifts then as you speed up to 50 mph it engages. Just had top and bottom motor mounts replaced. Still has a vibration when parked. No check engine lights on ever or anything.
Jul 14, 2019 at 5:27 AM
Good afternoon,
I would start by changing the fluid and filter in the transmission. A clogged filter will cause this issue.
Also, check the fluid and smell it. See if it smells burned or varnished.
https://www.2carpros.com/articles
Jul 14, 2019 at 6:10 AM
BOB OSBORNE
Okay thanks. will start there.
Jul 14, 2019 at 10:17 PM
You are welcome.
Always glad to help.
Jul 14, 2019 at 10:31 PM
