Is it possible for my transmission to slip due to low fuel?
2002 JEEP GRAND CHEROKEE LAREDO
2,100,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
JEFFREY BALDWIN
  • 5 POSTS
It seems every time my low fuel light is on the transmission doesn't want to shift out of first but then does when revved up to about 5,000 RPMs. Yikes! Am I losing it?
May 5, 2024 at 4:37 PM
  • 110,236 POSTS
There is no correlation between the fuel level and the transmission function. Have you checked to make sure the fluid is full and clean? That is where I would recommend starting.
Here is a link that you may find helpful:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
If that appears to be in good condition and full, I will need to know if the check engine light is on while the engine is running. If it is, we need to scan for diagnostic trouble codes to see if there are any stored that are related to the transmission.
Here is a link that explains how to scan all modules at one time (can-bus):
Let me know if you have already done these things. If so, what were the results?
May 6, 2024 at 1:06 PM
