after putting it in gear it does not want to gain any speed
20,000 MILES • 0.5L • 6 CYL • 2WD • AUTOMATIC
CHRISTOPHER PETERSON
Transmission is hesitant after putting it in gear it does not want to gain any speed, this only happens sometimes. The car was running fine on Friday I parked it after work started it on Sunday to go to the store and this transmission problem started.
Feb 12, 2018 at 3:05 PM
Good morning.
When was the last time you changed the oil/filter in the transmission? A clogged filter will cause this issue. Here are two guides that can help us fix it
and
Please run down these guides and report back. Is the check engine light on?
Apr 13, 2021 at 11:49 AM
Thank you for your help. I need to know what the light on the dash board next to the ABS light is for.
Christopher Peterson
Did that come on when the ABS light came on??
Trac control.
