Transmission not shifting properly
20,000 MILES • 0.6L • 6 CYL • 2WD • AUTOMATIC
JACKIE CAMPBELL
Truck was doing fine except sometimes would hang shifting from 2nd to 3rd, would let off gas then would shift fine. Then yesterday my 4 year old decide he was going to help wash carpet in my truck and flooded floor from back seats up with hose . The water puddled pretty bad in passenger floor board. Got all water out . Was going to take it to town to vacuum it out. Start out fine and about a mile half down road started slipping. Lost all gears pulled over shut it off . Sat there a min and then tried back in 1st it engaged so I shifted manually all the way to drive held until I slowed down and let off gas . Then all was lost again . Turn off . Restarted 5 minutes later . And repeated the process. If put in drive to start it would shift till going in 3 would not shift. so this process I used to get truck home about 9 miles . I go until I had to let of gas . Then stop and try again never got over 3500 on tachometer. Would never pick up good speed . About 35 was the highest. Don't know if carpet has anything to do with it . But that's the only major change.
Jun 23, 2021 at 12:38 AM
  • 55,709 POSTS
We should make sure the fluid level is okay. but it sounds like the pressure regulating solenoid #3 is out. Here is the location so you can check it out with instructions on how to check the fluid level. lets run the codes as well.
Jun 24, 2021 at 5:38 AM
JACKIE CAMPBELL
Okay, I will go check that out . I hook up a Diablo 2 scanner and programmer to it . And it shows no codes . But i have also read you have to have particular scanner for transmission codes. But I'll do what you said and get back with .
Thanks, jackie
Jun 24, 2021 at 7:13 AM
  • 55,709 POSTS
The scanner should pick up transmission codes as well. This could be a bad PCM which is common. Let me know after fluid and pressure regulating solenoid check replacement.
Jun 28, 2021 at 1:20 AM
JACKIE CAMPBELL
Still have no scanner but I did however learn the odometer test mode codes and the codes are as follow:
9352??
D041 SCP invalid ,missindata car
Speed
D123 SCP wrong or loss of odometer data
9318 battery low
D262 lost or missing SCP message
Also a day or two before this happened I guess my fuel vent line got stopped up and I can't put but I don't know it takes me about 10 minutes to put three gallons of gas would this have anything to do with it?
Jul 25, 2021 at 3:54 AM
We need to use a scanner to get the actual codes. These are all cluster codes that could point to shifting issues but they are not going to directly relate to a powertrain issue so we really need to get the codes.
You can stop by a parts store if you don't have a scanner to get them and that should get them for us.
However, these SCP codes are pointing to a communication network issue so that is good to know as we should have some codes that will point us in the right direction.
I attached below a quick explanation of these modules and the SCP system.
Please let us know what you find and we can go from there. Thanks
Jul 29, 2021 at 11:10 AM
JACKIE CAMPBELL
Yes, I agree . I'm going to day to get a code scanner
And the kit required to check my fluid .. I will hop on here ASAP I know anything .
Thank you for the attachment.
And your time.
Jul 30, 2021 at 1:03 AM
Thanks so much for updating us. We will wait to hear back with what you find. Thanks
Jul 30, 2021 at 8:16 AM
