Possible transmission slipping issue
119,000 MILES • 3.3L • V6 • 4WD • AUTOMATIC
IMAGING
  • 151 POSTS
I don't know if my vehicle has transmission slippage. Every now and then when I rev up the car, RPMs go up but the car doesn't go anywhere until about 5 seconds later. It delays. Like I said before, there are days that pass and this doesn't happen. So I don't know what it could be.
Apr 20, 2021 at 11:05 AM
Good morning,
I would start by checking the level to be sure there is enough fluid.
I would also suggest changing the fluid and filter. If the filter is partially clogged, it will do this.
Apr 20, 2021 at 9:27 PM
IMAGING
  • 151 POSTS
I did check the levels and they are correct. Now, you don't recommend a flush.
If I change the filter, should I change the gasket?
So even though this doesn't happen all the time, it's still considered a slippage?
How about the Lucas Stop Skip fluid? Should I use that?
Apr 21, 2021 at 3:37 AM
No, do not do a flush, just a fluid exchange. The flushing agent damages the clutches.
Yes, always change a gasket. Never reuse an old gasket.
No additives, They have no effect on the issue.
Apr 21, 2021 at 5:12 AM
