The slip light warning keeps appearing on the car dashboard?
111,300 MILES • 1.6L • TURBO • 2WD • AUTOMATIC
AFRICA BLACK
And it slows down the car. I can't drive above 60, whenever I try to go above 60, the car will vibrate and slow down then the slip warning light will flash on the dashboard. I have been to a mechanic shop, the car technician tried to solve the problem, but it keeps coming back.
Dec 31, 2024 at 7:08 PM
  • 55,711 POSTS
Can you give me more details about what was done to try to fix it? Are there any other warning lights on the dash? Also, are the tires all the same size? If not, this will be the problem. I would do a CAN scan to check the YAW sensor and the steering angle sensor operation. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
If these check out, you could have a traction control/ABS module that is going out. Please go over this guide and get back to us.
Jan 1, 2025 at 7:10 AM
