Slip indicator flashing, car not moving
137,000 MILES • 3.4L • 6 CYL • 4WD • AUTOMATIC
VALF
I got another problem. There are lot of times when I am approaching stop signs I calculated my speed so that when I reach the intersection my car will almost stop just in case the light turns green and I can accelerate. But when I tried to accelerate and stepped on the gas my car won't move, my slip indicator is flashing even when the road is not slippery and there was no engine sound/acceleration sound when I stepped on the gas repeatedly. My car will only move if I fully step on the brakes and make a full stop only then my car will move and go on my way.
Thanks again,
Val
Jan 24, 2019 at 12:36 PM
  • 110,248 POSTS
Hi and thanks for using 2carpros,com
Based on your description, it sounds like there is a problem with one of the wheel speed sensors. They are responsible for actuating the anti lock brakes as well as traction control. If the computer senses that one of the wheels isn't turning as fast as the others, it thinks the vehicle is slipping. As a result, it engages traction control, which reduces engine power to eliminate slip. When you stop the vehicle, everything goes to 0mph and the system starts working again.
Now with that in mind, you need to check wheel speed sensors. To do that, you will need a live data scanner so you can actually see what each wheel speed is and if one is off. If you don't have a scanner, you will need to have the computer scanned (most parts stores will do it for free). The only problem, if there isn't a code set, and there may not be, they won't be able to help. In that case, you need to have someone drive the vehicle while watching wheel speeds via a live data scanner. They will have to cause the vehicle to do what you described while they watch what is happening. Here is a quick video showing how it is done.
https://youtu.be/YV3TRZwer8k
If you have no way of scanning the computer or accessing a live data scanner, here is a link that shows how to do it a different way.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Here are a couple links that you may find helpful when testing:
Here is a link that shows in general a speed sensor being replaced.
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
If you find one of the sensors is bad, here are directions for replacement. There are two different procedures. One is for the front, the other the rear. I will start with the front. All attached pictures will correlate with these directions.
______________________________________________
SPEED SENSOR, FRONT
Front Wheel Speed Sensor
See Pic 1
REMOVAL
REMOVE SPEED SENSOR
See Pic 2
a. Disconnect the speed sensor connector.
b. Remove the 4 resin clips and 3 clamp bolts holding the sensor harness from the steering knuckle, upper arm and side rail.
Torque:
Steering knuckle and upper arm: 8.0 Nm (82 kgf-cm, 71 inch lbs.)
Side rail: 12 Nm (122 kgf-cm, 9 ft. lbs.)
c. Remove the speed sensor installation bolt from the steering knuckle.
Torque: 8.0 Nm (82 kgf-cm, 71 inch lbs.)
INSTALLATION
Installation is in the reverse order of removal.
CAUTION:
^ There are no foreign objects on the sensor or the part of the knuckle to which the sensor is to be installed.
^ The sensor is installed flat against the knuckle when you tighten the bolt.
HINT: After installation, check the speed sensor signal.
________________________________________________
Rear sensor:
SPEED SENSOR, REAR
Rear Wheel Speed Sensor
See Pic 3
REMOVAL
REMOVE SPEED SENSOR
a. Disconnect the speed sensor connector, and pull out the sensor wire harness with grommet.
b. Remove the 5 resin clips, holding the sensor wire harness from the frame, upper control arm and axle housing.
See Pic 4
c. Remove the mounting bolt and speed sensor.
Torque: 10 Nm (100 kgf-cm, 7 ft. lbs.)
INSTALLATION
NOTICE: Make sure that
Jan 25, 2019 at 11:35 AM
