I noticed RPM drop at a consistent rate while sitting idle when in drive or reverse. When it's in neutral and no transmission load it isn't enough to be noticeable any more. Its only a slight RPM drop (maybe 50 to 100 rpm's) but enough to shutter the car. I replaced the plugs and replaced the coil about 10,000 miles ago. In the attached video you can hear a possible slight pressure build and when it hisses with the release of the pressure is when the idle drops. I checked the PCV valve which is a common fail item on these vehicles but don't have any noticeable leak from it. Any help is appreciated.
Jun 26, 2020 at 11:32 PM
