Slight hum after having the transmission replaced?
132,394 MILES • 3.6L • V6 • AUTOMATIC
WJMNKY
Hi, I just had the transmission replaced recently after it went out on me and when I got it back from the shop, I’ve been hearing a slight hum that comes and goes when I apply the brake or decelerate. I’m just wondering what could be causing that noise since the transmission has been recently replaced?
Apr 12, 2025 at 11:45 PM
  • 55,711 POSTS
Was the noise there as soon as you got the van back? If so, the transmission is defective, can you upload a short video from your phone of the noise? That way I can tell for sure. There is a chance the wheel bearing hub has gone out; can you tell me which side of the van the noise is coming from?
Apr 13, 2025 at 6:33 AM
WJMNKY
I started hearing it when I first had to start braking to slow down so I was not sure which side it was coming from. What I feel like is happening is it’s having a hard time powering down or slowing down since the slight hum is happening in between the deceleration and acceleration. I’m going for a test drive with the shop that put the transmission in tomorrow. I just wanted to know the possible options before I did the test drive tomorrow.
Apr 13, 2025 at 10:08 AM
  • 55,711 POSTS
Okay, I am here for you if you need to help confirm the repair or if you feel something is not right with what they are telling you.
Apr 14, 2025 at 2:33 AM
