Slide door noise?
123,000 MILES • V6 • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
I am sure you have seen this before, can you tell me what can cause it? Both doors open from buttons on head panel or from buttons on side but not when i lift the handles both while closed or open, don't they open like odysseys? Passenger side works but i have to lift it to move or it just keeps making this noise. I'll send video.
Sep 17, 2025 at 2:06 AM
  • 55,766 POSTS
Yep, the is a stripped drive gear on the cable control system, you will need to remove the drive motor for inspection/replacement. Make sure the drive is not stripped. Check out the images (below). Please upload pictures or videos in your response.
Sep 18, 2025 at 4:03 AM
BHAMDOC1973
  • 2,007 POSTS
How do i get to the motor?
Sep 18, 2025 at 4:10 AM
  • 55,766 POSTS
Remove the door panel on the sliding door. The drive motor should be there.
Sep 18, 2025 at 9:00 AM
BHAMDOC1973
  • 2,007 POSTS
And this ring is inside the motor? Or just get a motor assembly if its stripped i guess.
Sep 18, 2025 at 9:32 AM
  • 55,766 POSTS
You can open up the motor to help confirm the issue.
Sep 18, 2025 at 9:49 AM
BHAMDOC1973
  • 2,007 POSTS
are we talking about the sliding door lock actuator or the slide door motor?
Sep 19, 2025 at 5:07 AM
  • 55,766 POSTS
The slide door motor? Does the lock make noise? I assumed the door was open when making the noise.
Sep 19, 2025 at 9:55 AM
BHAMDOC1973
  • 2,007 POSTS
Ya it opens and closes. The lock closes and opens fine so i dont think its an actuator issue like some of the people having issues with theirs
Sep 19, 2025 at 10:03 AM
  • 55,766 POSTS
So does it make the noise when in operation or when locking?
Sep 19, 2025 at 10:04 AM
BHAMDOC1973
  • 2,007 POSTS
the sliding door makes. noise when I want to close the door but it won't move and just makes that noise until I help it by pulling on the handle that is on the outside for it to move and close
Sep 19, 2025 at 11:52 AM
BHAMDOC1973
  • 2,007 POSTS
I removed the door cover, it turned out it was actually the lock door actuator making the noise not the slide door motor, I was mistaken. How hard are they to replace
Sep 20, 2025 at 7:55 AM
  • 55,766 POSTS
It is not to difficult to do, here is a diagram to help.
Sep 21, 2025 at 1:34 AM
BHAMDOC1973
  • 2,007 POSTS
Ugh, replaced it and same thing, its coming from the assembly it attaches to i guess. What is it called?
Sep 22, 2025 at 8:09 AM
  • 55,766 POSTS
Yep, that is the drive motor, it is bad. Thanks for the video it helps.
Sep 22, 2025 at 10:27 AM
  • 55,766 POSTS
So did the drive motor fix it?
Sep 26, 2025 at 11:40 AM
BHAMDOC1973
  • 2,007 POSTS
I replaced the latch assembly with the motor and the noise went away but now am dealing with the issue of closure which I asked a new question about
Sep 26, 2025 at 10:09 PM
  • 55,766 POSTS
Thanks for letting us know.
Sep 27, 2025 at 4:10 AM
