Slave cylinder and throw out bearing replacement
53,000 MILES • 5.0L • V8 • 2WD • MANUAL
BHARPER33
I am needing a slave cylinder and throw out bearing for my car listed above gt model. All the slave cylinders I see have 2 holes at the bottom where you connect it, but I am needing one that has 4 holes at the bottom where it connects. where can I get that? Down below is a picture of what I need but instead of just having 2 holes I need 4 as you can see in the picture.
Jan 11, 2020 at 7:36 AM
  • 110,248 POSTS
Can you upload the pic? It didn't attach.
I attached a pic from my manual for this vehicle. Are we referring to the same part?
Jan 11, 2020 at 10:22 AM
BHARPER33
Yes, that’s the same part. as you can see in the image there are 4 holes but the only one I can find for this has 2 holes.
Jan 12, 2020 at 12:14 PM
  • 110,248 POSTS
I have never seen one with 4. I even checked the 5.4L and it's the same as the 5.0 and 3.7. Have you contacted the dealer to see if they have any suggestions? Did you remove 4 bolts?
Jan 12, 2020 at 2:10 PM
