loses power intermittently, stops
175,000 MILES • 4 CYL • FWD • AUTOMATIC
ZOOBIE
sometimes loses power when accelerating and actually stops running at stop lights. I have had the alternator and battery tested, both good. Someone mentioned sensors that could be shutting off the engine. How would I test? I have no sensor codes or meter. Thanks
Aug 13, 2016 at 6:54 AM
SATURNTECH9
  • 30,869 POSTS
Does the check engine light ever come on when it is running? Also when you loose power you should have the exhaust tested for excessive back pressure.
Aug 13, 2016 at 11:04 AM
ZOOBIE
Yes, the check engine light comes on while driving then turns off. I just came back from a drive. It shut off at just about every stoplight. Then, it starts as if nothing happened. On the way back, it drove normally and did not shut off once. I cannot really be spending any money testing because as soon as I replace it, it is going to the boneyard. Thanks
Aug 13, 2016 at 11:49 AM
SATURNTECH9
  • 30,869 POSTS
So are you looking to fix it or are you just scraping it? You could have a sticking EGR valve which you could clean to get by for a little while.
Aug 13, 2016 at 12:01 PM
ZOOBIE
I am looking to fix it so I can get to and buy another car.
It runs strong.
It just tries to die, cough, and lose power even shuts off whenever it wants.
It especially hates stoplights while idling.
Can bad sensors shut down the engine?
Thanks
Aug 13, 2016 at 1:57 PM
SATURNTECH9
  • 30,869 POSTS
Again it sounds more like a sticking EGR valve, but a bad coolant temperature sensor on that car can cause some crazy things to happen even dying. A map sensor can cause dying as well.
Aug 13, 2016 at 2:59 PM
SATURNTECH9
  • 30,869 POSTS
SATURNTECH9
  • 30,869 POSTS
There is a how to so you can see what codes you have. Let me know what the code numbers are.
Aug 13, 2016 at 3:06 PM
