2002 Skoda Octavia Engine not accelerating
GAURAVTYAGI79
Electrical problem
2002 Skoda Octavia 4 cyl Two Wheel Drive Automatic
my car had a start problem , changing of the ignition coil solved the start problem also the garage changed the lamba sensor as it also need replacemnet , but now my car did not accellerate i mean its started but pressing the throttle paddle does not do any effect ,,, the garge folks replcaed the TPS (throttle position sensor ) but its does not help and situation remians the same .... what could be the issue ,,,the fault code jus say that the hight voltage sent to TPS ,,,plz advice
Jan 29, 2010 at 5:06 AM
DAVE H
  • 13,383 POSTS
start by resetting the PCM .. if this fails replace the PCM
Feb 22, 2010 at 1:03 AM
