2006 Skoda Fabia windscreen wipers
2006 SKODA FABIA
ALISTAIRAMTHR
Electrical problem
2006 Skoda Fabia Front Wheel Drive Manual 43250 miles
i have a 2006 skoda fabia the windscreen wipers dont work at all , however sometimes if you pull the arm as if you are using the wash wipe it will work once , the windscreen washers are not working either.
Jan 11, 2010 at 12:24 AM
DAVE H
  • CAR REPAIR CONTRIBUTOR
  • 13,384 POSTS
Hello .. thanks for the donation .. much appreciated Start by checking the fuse and relay .. I suspect the problem is the actual wiper switch (arm) is faulty and may need replacing !
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_951.png
Jan 11, 2010 at 4:41 AM
