Can I get brake master cylinder replacement instructions?
17,500 MILES • 4 CYL • FWD • MANUAL
ALAN SECCOMBE
I have only done 17,500 miles since new and my master cylinder is leaking can you help?
Jun 22, 2008 at 10:05 PM
BORIS K
  • 836 POSTS
Is the brake master cylinder leaking externally? can you see any brake fluid outside at the brake master cylinder? Or is the brake fluid level dropping in the reservoir without any visible external leaks?
If the 2nd scenario is applicable you need to check the brakes lines and callipers/drums at the wheels first for any possible leakage, please see pictures below.
If no leaks are visible at the wheels then I would suggest to remove your brake master cylinder. Check for any leakage at the rear of the brake master cylinder. See picture below. Also check for any traces of brake fluid in the brake booster. If any brake fluid is found in the brake booster this should be drained out. Best practice is to replace the brake booster as the brake fluid will cause the rubber diaphragm to perish and eventually fail.
How to replace a brake master cylinder see instructions below.
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
and bleed brakes
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Please let us know how you get along.
Cheers, Boris
Apr 22, 2021 at 8:32 PM
  • 55,628 POSTS
Here are the master cylinder installation instruction you have requested. Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car:
https://youtu.be/WDxvEQrMkBg
and
https://youtu.be/w7gUsj2us0U
and
May 11, 2021 at 10:08 AM
