2003 Skoda Fabia Engine light appears
55,560 MILES • 4 CYL • FWD • MANUAL
NEBUPM
when i start the car, the engine light stays on, i checked with the garage and they checked the computer on the car and they said its because of the oxygen sensor and they have reset it.
I drove the car for an hour or so and then ir appeared again?
Does it show that anything is wrong with the car?
help is highly appreciated.
Jul 25, 2009 at 11:58 PM
DAVE H
  • 13,383 POSTS
It will be the O2 sensor needs replacing or another fault (ie. MAF sensor over/under fueling)is causing the sensor to show the wrong values .. the garage should be able to track this down for you !!
Sep 7, 2009 at 9:55 PM
