2001 Skoda Fabia not working
45,676 MILES • 4 CYL • 2WD • MANUAL
TREVORMARCH
had recharged and checked for leaks, air con switch lighting up,not cooling,fan sometimes works and then stops.Fitted evap valve sensor under dash as advised on google search.All fuses good.Checked feed to compressor and has permanent feed as advised on net search.The air con pipes on inner wing near a sensor are not cold. Any ideas.
Jun 29, 2010 at 6:53 AM
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation You need a UV light and glasses after adding dye to check for leaks .. did you do this ? ..sounds like the system is not charged fully or has a leak.. check you have the correct freon pressure in the system !
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_1161.png
Jun 29, 2010 at 9:54 PM
TREVORMARCH
Have had checked,presure good.
Jun 30, 2010 at 12:30 AM
DAVE H
  • 13,383 POSTS
which fan is only working some of the time ? the readiator fan or internal heat/ac fan ?
Jul 1, 2010 at 9:45 AM
