had recharged and checked for leaks, air con switch lighting up,not cooling,fan sometimes works and then stops.Fitted evap valve sensor under dash as advised on google search.All fuses good.Checked feed to compressor and has permanent feed as advised on net search.The air con pipes on inner wing near a sensor are not cold. Any ideas.
Jun 29, 2010 at 6:53 AM
