2001 Skoda Fabia abs senser rings
PEDROS892
Brakes problem
2001 Skoda Fabia 4 cyl Two Wheel Drive Manual
Fitted new ABS senser on front off side wheel. ABS warning light gone out Whilest driiving the traction control light keep flashing and applying breakes. Think fault my be to do with magnetic rings Where are they located are they on drive shaft or to do with bearig hub. Fault seems to follow changing of wheel bearing
Sep 16, 2010 at 3:19 AM
DAVE H
  • 13,383 POSTS
Hello . thanks for the donation .. much appreciated
ABS sensor rings are part of the CV assembly
Sep 16, 2010 at 9:37 PM
