Skipped or bad timing chain
176,400 MILES
TRACYDELNOR
One day my car ran fine and the next it would not start for two weeks. the mechanic changed all four spark plugs and then said it barely had power while driving it and said we needed a new ECM. so we replaced that and the mechanic put it in but never did the three step procedure but I did and it started right up. After two days it started losing power while driving it and ran rough. Then it would not start for two days. Different mechanic said it was the 02 sensor so changed it and now it is running rich and the mechanic is going to change the MAP sensor, but if that does not work he says it may be the timing chain. Would a timing chain cause the car to run rich and lose power on acceleration? Please help it is our only car and I am disabled and my husband has not worked in four months.
Feb 19, 2018 at 9:38 PM
Good morning.
Does it have any codes stored for the check engine light?
Has anyone checked the catalytic converter?
Feb 19, 2018 at 9:50 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Check the fuel pump pressure, because if it is too high maybe due to a kink in the fuel line, it could be causing the too rich fuel mixture, but by all means have the engine trouble codes retrieved.
the fuel pressure should be 50-60 psi.
Feb 19, 2018 at 10:08 PM
TRACYDELNOR
The mechanic just called to say they took the cover off and the timing chain is extremely loose and it jumped. He is going to price it out for me to see if I can afford to have it replaced. Do you have an idea of how much it would cost to have it done?
Feb 19, 2018 at 10:12 PM
Okay, good.
My concern is this. If it jumped, then there is a chance the valves have been damaged and the head will have to be removed and a valve job done.
Call him back and ask him if there is any valve damage before starting the job.
As far as price, $500. to $800.00 is in the ball park depending on your area. If there is valve damage, the price goes way up to about $1,500.00 to $1,800.00.
Feb 19, 2018 at 10:43 PM
