When accelerating my engine has a skip
190,000 MILES • 4 CYL • 2WD • MANUAL
WILLIAM TIPPER
My car has a bad skip in it when I take off. what is the best way to clean the injectors?
Oct 22, 2016 at 10:16 PM
WRENCHTECH
  • 20,760 POSTS
Injectors have to be chemically pressure cleaned and even then, they do not always come clean. Many shops have system that will have the engine run on a chemical out of a container. They can also be removed and sent out. Most of the time you are better off just isolating the bad one and replacing it.
Oct 22, 2016 at 11:02 PM
WILLIAM TIPPER
Thank you, I will have this done.
Oct 22, 2016 at 11:12 PM
SATURNTECH9
  • 30,869 POSTS
You could even have a ignition issue. I would say that is probably more likely. Have you checked for codes in the computer yet?
Oct 23, 2016 at 11:21 AM
