Sinking brakes
240,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
DAVIDDEGUZMAN
  • 6 POSTS
When engine is off brakes are working good. when engine is on specially when rolling for stop the brakes start sinking also a hissing noise when pressing the brake pedal. new caliper,wheel cylinder and ABS hydraulic unit.
Jun 19, 2017 at 5:18 AM
DAVIDDEGUZMAN
  • 6 POSTS
ABS light is on.
Jun 19, 2017 at 5:35 AM
CARADIODOC
  • 34,391 POSTS
Was the brake pedal sinking before the parts were replaced? If it was not, a good suspect is the master cylinder was damaged from improper bleeding procedures.
For the ABS system, most likely a scanner is needed to open some of the valves in the ABS hydraulic controller so trapped air can be bled out. The diagnostic fault codes need to be read and recorded too to see if the problem is related.
Jun 19, 2017 at 3:09 PM
DAVIDDEGUZMAN
  • 6 POSTS
The pedal is sinking before all parts was change. ABS light is on, before van was not driven for more than a year pedal was okay.
Jun 20, 2017 at 1:41 AM
DAVIDDEGUZMAN
  • 6 POSTS
I will get the ABS scan today, thank you.
Jun 20, 2017 at 1:42 AM
CARADIODOC
  • 34,391 POSTS
The scanner will show a fault code that has turned the ABS warning light on. It is also usually needed to bleed the system. That may solve all the problems so I'll wait to hear how that turns out.
Jun 20, 2017 at 1:16 PM
DAVIDDEGUZMAN
  • 6 POSTS
Thanks I will do that tomorrow. When you mention bleed the system? What parts of the brake system!
Jun 20, 2017 at 5:00 PM
CARADIODOC
  • 34,391 POSTS
You replaced the hydraulic controller. That is going to have air in it. Typically there's two chambers that have air trapped in them. The scanner will have a menu choice that commands the computer to open the valves to let that air out so it can go to the wheels and be bled out.
Jun 20, 2017 at 5:11 PM
