Get starter replaced and make sure that the teeth on the drive plate, are not worn down, these are the teeth that the starter engages to turn the engine over when stating, if these are worn, you will have to replace the drive plate which will require the removal of the transmission.
Tuesday, August 2nd, 2016 AT 2:35 PM
